<Picture sorting function suggestion>——very important
xxx丶
Hello, development team. I hope you can come up with a function that allows pictures to be sorted according to the order in the picture folder, otherwise the order of pictures in each folder is different, which is very troublesome to switch and affects the use. I hope you can pay attention to this function, thank you.
Re: <Picture sorting function suggestion>——very important
Have you checked whether a combination of the options available in the browser View > Sort by menu would meet your requirements?
xxx丶
I have tried to switch between various sorting methods, but none of them are consistent with the image sorting inside the folder. You can only sort by date, but it will make all folders read by date, and I want Xnview to read the order of the images inside the folder, which is the best. Thank you.cday wrote: Fri Jan 26, 2024 9:45 am Have you checked whether a combination of the options available in the browser View > Sort by menu would meet your requirements?
if you means the sort order of windows explorer, we can't get it
