XnView MP doesn't treat all DWG files consistently
lphilpot
Post by lphilpot »
XnView MP 1.6.4 on Windows 11
I have a small collection of simple DWG drawings in a folder and XnView MP doesn't treat them all the same. When the "All" filter is enabled, some are shown as thumbnails while others have the associated app's icon (QCAD). Although QCAD created these files, they're standard AutoCAD formats.
If I enable the "Images (+Folders)" filter (my preferred filter) the files with the QCAD icons disappear.
The drawings are a mixture of ACAD version formats: R11/R12, R24 (ACAD 2010), R27 (ACAD 2013) and R32 (ACAD 2018). However, the "show / doesn't show" behavior isn't consistent with the ACAD versions. For example, here's a list of the files and XnView's treatment of them:
Drawing file                                                         ACAD ver.      XnView shows
hex1_R12.dwg                                                         R11/R12        icon
compass_rose.dwg                                                     R24 (2010)     preview
dimension1.dwg                                                       R24 (2010)     preview
garden_cart_shelves-nanocad.dwg                                      R24 (2010)     icon
garden_cart_shelves.dwg                                              R24 (2010)     preview
hex1_R12-new_block.dwg                                               R24 (2010)     preview
xref_test.dwg                                                        R24 (2010)     preview
assign_2-office_space.dwg                                            R27 (2013)     icon
laptop_box.dwg                                                       R27 (2013)     preview
Mag wheel.dwg                                                        R27 (2013)     icon
tablet_case-alt.dwg                                                  R27 (2013)     preview
tablet_case.dwg                                                      R27 (2013)     preview
Apache 3800 case foam layout grid.dwg                                R32 (2018)     icon
bird feeder tray pole attachment cross-section.dwg                   R32 (2018)     icon
Lite-Roc tripod legs angles.dwg                                      R32 (2018)     icon
Manfrotto 3211 photo tripod cap and bubble level platform.dwg        R32 (2018)     icon
Manfrotto 3211 photo tripod leg end.dwg                              R32 (2018)     icon
Paper_space_viewport_practice.dwg                                    R32 (2018)     icon
QCAD book ortho projection assignment.dwg                            R32 (2018)     icon
QCAD-logo.dwg                                                        R32 (2018)     icon
Samsung Tab A flat frame cover.dwg                                   R32 (2018)     icon
twisted wire.dwg                                                     R32 (2018)     icon
walking stick grip clamp band template.dwg                           R32 (2018)     icon
weather station mounting plate.dwg                                   R32 (2018)     icon
Whether XnView shows or doesn't show them is mixed even within the same version. I can provide a couple of sample files if desired.
Thanks.
Len Philpot
Re: XnView MP doesn't treat all DWG files consistently
XnView MP use third party plugin for DWG, so seems that all files can't be loaded
