Catalog backup and management
Post by michel038 »
I suggest redesigning the "File's categories" menu in the categories panel :
1) Rename this entry "Catalog"
2) Specify "Export as xml"
3) Specify "Erase and import xml"
4) If possible, add "Import and merge xml"
5) Add a "Save as..." action which will simply offer to save a copy of xnview.db in a classic save dialog.
This package should also be accessible via the "File" menu :
File > Catalog > Export as xml
File > Catalog > Erase and import xml
File > Catalog > Import and merge xml
File > Catalog > Save as ...
Other less important suggestions:
6) Add "Import photos" , which will work in the same way as the "Add folder" button in settings,catalog (in my opinion, it's not a setting, but an action).
7) Add "Erase currentDB, and Import Xnview classic db" ( instead of Settings>Catalog>Tools tab )
Another audacious suggestion :
8 ) Offer the possibility of working on different catalogs :
- Switch from catalog A to catalog B = save XnView.db into catalog A.db and copy catalog B.db into XnView.db (+restart ?) seems easy to implement ?
Re: Catalog backup and management
michel038 wrote: Sun Jan 28, 2024 4:04 pm 1) Rename this entry "Catalog"
Ok
json can be selected too
ok
I think that it's better to copy the file from folder....
Better than in 'categories' panel? so i can remove it from this panel?
yes can be implemented, but need some work...
Post by michel038 »
Ok
Thanks :D
2) Specify "Export as xml or json"
3) Specify "Erase and import xml "
:D
ok
:D
Do you mean :
-Close XnViewMP
-Open Windows explorer
-Open C:\Proram files \...\Xnviewmp folder
-Copy Xnview.db to another place
Several users come to the forum calling for help, for not having thought of this ...
Providing a "File > Catalog > Save as ..." menu would help.
File > Catalog > Export as xml or json
I don't know if it's relevant to remove it now. pehaps better to wait some further versions, and keep both places for some months.
File > Catalog > Switch ...
xnview wrote: Mon Feb 05, 2024 2:48 pm
michel038 wrote: Sun Jan 28, 2024 4:04 pm This package should also be accessible via the "File" menu :
yeah, just remove it from Categories - parent elements should not be in child menu
However, I think potentially there are too many items to be grouped under one Catalog menu, some of them need to be flattened out.
So I thought of a separate menu group to make it clearer, but "File" would work too (more or less) since most apps use it that way.
michel038 wrote: Sun Jan 28, 2024 4:04 pm 5) Add a "Save as..." action which will simply offer to save a copy of xnview.db in a classic save dialog.
+1
moreover, I think "Save as" functionality shall shift focus to the new file which is not the case here.
if bother at all, making copy of db can be inside "Export..." as .db among .xml, .json options.
