1.6.4 - browser - thumbnails - cached size affects size of some thumbnails
XnViewMP 1.6.4 64bit
Browser - thumbnails
0. run clean app with default settings (Thumbnail size is 128x96)
1. goto Settings > Catalog
- set Thumbnail caching size to some small value, eg 10x10
- press OK
2. restart app
issue A
3. open Browser
size of the following thumbnails should not be affected:
- folder icon
- txt, xmp
- video
issue B
images have strange 128px threshold
issue C
3. goto Settings > Catalog
- (optional) delete all Catalog records
- disable Catalog
- press OK
4. restart app
5. open Browser
thumbnails are still affected by 10x10px setting
Why?
Once Catalog is off thumb's size shall switch to Browser's menu value (default 128x96 in our case), not remain 10x10 (from Settings > Catalog > Thumbnail caching).
Re: 1.6.4 - browser - thumbnails - cached size affects size of some thumbnails
user0 wrote: Mon Jan 29, 2024 5:34 am
issue A
3. open Browser
- folder icon
- txt, xmp
- video
why, thumbnails are stored in catalog too
issue B
what do you means?
issue C
- disable Catalog
- press OK
4. restart app
5. open Browser
Why?
I can't reproduce, thumbnails will be rebuilt
A
xnview wrote: Thu Feb 01, 2024 3:12 pm why, thumbnails are stored in catalog too
it looks like representation issue, not storage, check how my filelist looks below (top row is folders)
I think the correct behaviour:
- mentioned object types shall be shown at current thumb size (128x96), not 10x10
- cached thumb (10x10) shall stretch to the current thumb size (128x96) as it happens already
B
xnview wrote: Thu Feb 01, 2024 3:12 pm what do you means?
2 almost identical files (128x128 and 129x129) should not have such radically different thumbs
b_test_img.zip
(474 Bytes) Downloaded 223 times
C
xnview wrote: Thu Feb 01, 2024 3:12 pm I can't reproduce, thumbnails will be rebuilt
nope, clean unzipped version
Thumbs return to normal (size and resolution) only if 'Enable thumbnails caching' checkbox is unchecked and manual 'Rebuild thumbnails' in Browser (or goto other folder / app restart).
i understand but not so easy :D
- Non image files, right, thumbnail should be stretched
- Image files:
Catalog: 10x10, Thumbnail: 128x128
If we have image file :
- 256x256 => stretched to 128x128
- 8x8 => not stretched
- 90x90 => should be stretched to 90x90 and not 128x128
xnview wrote: Fri Feb 02, 2024 8:28 am - Image files:
right, agree
This problem is supposed to be fixed in XnView MP 1.6.5. Please check and confirm the bug fix here.
fixed in 165
