Lovely feature - Raising awareness - Holding SHIFT key to open multiple files in separate View tabs
budz45
Post by budz45 »
After all these years, I am still able to hold down SHIFT key whilst opening multiple selected files. This then causes XnView MP to open the image files in separate tabs :D :D
I believe it stemmed from this old topic:
viewtopic.php?t=24968
I think more awareness should be made about this feature, perhaps a printed message giving this tip in the Settings>Interface>Tabs
Furthermore as a suggestion, perhaps these ini Tweaks could be placed in a tab of the About menu
mtomy2008
Re: Lovely feature - Raising awareness - Holding SHFIT key to open multiple files in separate View tabs
Post by mtomy2008 »
Yeah you right @budz45, I agree with your suggestion to increase awareness about this feature. :) travelagu
