I am trying to make the keyboard shortcuts the same as used in Windows Explorer and browsers like Chrome as much as possible, as I know them very well. So, is it possible to move tabs using the keyboard? is there a command for this?
I can change tabs using ctrl-tab and back using ctrl-shift-tab, but I want to change that to ctrl-PgUp/PgDn and to move tabs using ctrl-shift-PgUp/PgDn.
Is this possible?
Thanks.
Is there a command to move tabs?
Re: Is there a command to move tabs?
no sorry
