Registration silent
Encalve
Registration silent
Post by Encalve »
Hello
we both 8 license for xnview. I found here a silent installation and it works fine.
Now my question:
Is there a way to give the license also silent? So when i click the install.bat, after the installation i dont have to put the code and name in.
thanks fo help
Enclave
ulrick59
use autoit
Post by ulrick59 »
If xnview can't register your version automaticly, you can use this software : autoit. it can simulate the mouse click, press keybord and more
Ulrick
Re: use autoit
ulrick59 wrote:If xnview can't register your version automaticly, you can use this software : autoit. it can simulate the mouse click, press keybord and more
I'm not so sure whether this answer is correct. I think only Pierre knows.
Re: Registration silent
Encalve wrote:Hello
Now my question:
No, do you use registry or .ini?
Aleksei
Post by Aleksei »
xnview wrote:
Encalve wrote:Hello
Now my question:
you mean that there is a way to put the registry to ini?
Aleksei
Post by Aleksei »
Sorry, i mean to put the license to ini.
