I have a question about XnConvert.
When I try to process images to reduce their file size, sometimes the file size increases instead.
Is there a way to avoid processing if it is going to increase the file size?
file size increases
Re: file size increases
which output format?
so in this case, you would like to keep original file?
monmon
I will explain with an image.
Is this kind of configuration possible?
I know how to reduce the size and delete the original image.
you have the setting 'Keep original file when encoded...' but the current version has some issues...
monmon
Thanks for the answer.
I'll try to find another way.
