1.6.4 Regarding increase in Webp file size due to libwebp version upgrade
abobong
Post by abobong »
I encoded it with the following settings.
In XnviewMP1.5.5,
This sample was able to convert 30 bytes.
In later versions, (in my case) I was able to encode with 34 bytes.
・ Is it possible to encode with 30 bytes even after XnviewMP1.5.5?
-postscript-
1. Extract cwebp from the latest libwebp-1.3.2-windows-x64.zip and
2. Built into the GUI.
3. Samples were compressed using the same settings as XnView MP
4. Compressed sample properties
For genuine libwebp-1.3.2,
I was able to compress it to 30 bytes without any problems.
I sincerely hope this post will help you share your issue across forums and your issue will be resolved...
Re: 1.6.4 Regarding increase in Webp file size due to libwebp version upgrade
Do you have the same output with latest cwebp?
abobong
Post by abobong »
thank you.
・Can be reproduced.
