Extremely slow conversion when converting to JPG Guetzli
masino
Post by masino »
Solved - the application does not freeze, it just takes an extremely long time to convert photos
Subject: 1.6.4: Extremely slow conversion when converting to JPG Guetzli
XnView: MP 1.6.4 - 64 bit
OS: Mac Sonoma 64bit
I use bulk convert and select the option to save to JPG Guetzli so the process starts but never finishes. The program freezes and I have to force quit it. The exported file has not been created.
Effect: Program hangs
1. I select any image format
2. I choose bulk convert
3. I set to save in Guetzli JPG format
4. I start the converter
5. the program hangs
Image Image
Re: App freezes when converting to JPG Guetzli
Processing time for output to JPEG Guetzli format increases very quickly as image dimensions increase, the format was only ever intended for reducing the size of webpage images... I believe that WebP is now the recommended format for reducing the size of images?
I have previously suggested that a warning be displayed when the format is selected, due to both the possible processing time and a limitation on the quality Q values that are supported. But there is a limit to what a single developer can do... :wink:
masino
Post by masino »
cday wrote: Sun Feb 04, 2024 10:53 am Processing time for output to JPEG Guetzli format increases very quickly as image dimensions increase, the format was only ever intended for reducing the size of webpage images... I believe that WebP is now the recommended format for reducing the size of images?
You are right, it took 7 minutes to convert one photo. I'm sorry it's taking so long, it looked promising to transfer the whole gallery.
