How to search in all subfolders?
mrwul
Post by mrwul »
Browser, at the top folder is set, for example: X:\Photos
In the search box some regex term.
It will show the photos according to the regex but only in \Photos
How to have XnViewMP (1.6.4) search thru all the sub folders as well?
Thanks.
Re: How to search in all subfolders?
Post by michel038 »
"Quick filter" (previous name = quick search) works only on displayed files in the browser.
So a solution is to use "View>Show files in subfolders" ...
But if your X:\Photos contains thousands of photos, it will not be efficient.
You can use "Search" function instead... which offers "récursive" option.
mrwul
Post by mrwul »
First of all, I am deeply sorry for not responding earlier.
For one reason or the other, your reply slipped my attention.
(At the time I was facing problems synchronizing Outlook desktop with smartphone, it took many days to solve)
Thanks for the below.
Indeed that is a nice solution.
Oh, BTW, I noticed the following and I am not sure if it is correct.
Say, XnViewMP is in browser mode.
Then do a search,
select any of the file in the results window panel
click on browse,
it will then replace the existing tab (with the previous browse)
From my point of view that may not always be convenient, it would be better to open the '2nd browse' in a separate tab.
Checked settings, but I am not sure if there is some setting to avoid this.
(Could very well be that I am overlooking something)
Any suggestions?
Thanks again.
Post by michel038 »
Then do a search,
click on browse,
You can
- Right click on a selected photo and choose "Open containing folder"
- Open the photo in view mode (double click) and then close the tab (depending on Settings > Interface > Synchronise browser when view is closed )
- Use the drop down field "search result" to select previously used folders in the history.
Opening a second browser is not a standard feature in XnviewMP ...
look for the words "figured out" in this forum to find a non-official method :mrgreen:
It would be a good idea to have the ability of opening a second browser with search results
