Images unselected after previously selected images had categories set
provanguard
I started using XnView MP as a DAM software for my photo collection recently. I set categories (mostly names of people) on my pictures. XnView writes the XMP files which is what I want, so that the RAW editing software I use afterwards can load them.
My process is as follows. I select one or more pictures in the list and then I click on the desired categories to assign them to the pictures. Here is where the problem I am having starts. To trigger writing down the XMP files to the disk I select another/next picture that I want to assign categories to. It takes some time for the operation to complete, which is understandable. The problem is that after writing is finished, the images I already selected become unselected. The result is that I need to actively wait until the unselecting happens in order to select the same new pictures again. This makes the operation of tagging images very annoying.
Please kindly change this behavior of images being unselected. Also please let me know if another way exists for triggering of writing the XMP files, e.g. keyboard shortcut, instead of selecting other pictures.
Re: Images unselected after previously selected images had categories set
I can't reproduce. On which format?provanguard wrote: Sun Feb 04, 2024 5:54 pm It takes some time for the operation to complete, which is understandable. The problem is that after writing is finished, the images I already selected become unselected.
provanguard
It is on the Nikon NEF files. The JPG is doing this as well.
Would the unselecting of selected image be happening because of what image format was having XMP files written for earlier?
i can't reproduce. post a screenshot of Settings>Metadata? and how do you assign categories?
provanguard
I have attached the screen shots. They are in reverse order, but I added descriptions with numbers.
provanguard
Here are my settings:
clicking on any file resets the current selection - is standard behavior that should not be changedprovanguard wrote: Sun Feb 04, 2024 5:54 pm To trigger writing down the XMP files to the disk I select another/next picture that I want to assign categories to. It takes some time for the operation to complete, which is understandable. The problem is that after writing is finished, the images I already selected become unselected.
press F5provanguard wrote: Sun Feb 04, 2024 5:54 pm Also please let me know if another way exists for triggering of writing the XMP files, e.g. keyboard shortcut, instead of selecting other pictures.
provanguard
You didn't get my point I think. The whole issue is about my selection being unselected without my direct interaction. Unselection happens after XnView finishes writing XMP files.
step 3 is your "direct interaction", press F5 insteadprovanguard wrote: Sun Feb 11, 2024 7:39 pm I have attached the screen shots. They are in reverse order, but I added descriptions with numbers.
1. Select one or more images
2. Click on the category to assign it
3. Click on another picture to trigger saving XML files.
4. Selected picture becomes unselected (undesired behavior).
ps. if companoin files are visible (not your case) - hide them or disable new files autoselection in Settings.
could you try to disable 'Settings>File list>Automatically select new files' or hide the companion files
provanguard
Thank you. This has worked for me: disable 'Settings>File list>Automatically select new files'
What does this option suppose to do? Where can I read documentation of all the options and features?
when files are added, there are selectedprovanguard wrote: Mon Feb 12, 2024 8:09 pm Thank you. This has worked for me: disable 'Settings>File list>Automatically select new files'
provanguard
Like any files added to a folder, even XMP files, which are not images and are not visible in the application?
Like .xmpprovanguard wrote: Thu Feb 15, 2024 5:24 pm Like any files added to a folder, even XMP files, which are not images and are not visible in the application?
