Hi, I'm brand new to XnView MP and quite impressed how customizable everything is, I really like this.
One thing I couldn't find in settings (or have overlooked): Is there an option to keep a copy of the original file when I edit it? I'd like to have a copy of the file like image-original.jpg because I need to keep the original filename for the processed image. Thanks for any hint!
Keeping original file when editing
Re: Keeping original file when editing
sorry but currently no way
nightowl
Ok, thanks for your answer!
Maybe a workaround, if it would be useful, could be to:
1. Copy the source files to another folder;
2. Use a batch renaming software to rename those files with the 'original' suffix;
3. Process the original files as you wish;
4. Then, if appropriate, combine the folders.
Edit: The XnView MP browser now contains a file renaming option that would probably be suitable.
nightowl
Thanks for the idea! We have an automatic import process I think it should be possible to add something like "create copy of imported image", will have a talk with our developers.
