Edit IPTC - date/time - improve UX
XnViewMP 1.6.4 64bit
improve UX of Create/Release date/time groups
Suggestion A
  • fix controls enable/disable logic
    selecting 2nd option should not enable controls of 3rd one
Suggestion B
  • remove empty item from combobox
    it may be used to blank current data in related field; however, 3rd option can do the same
Re: Edit IPTC - date/time - improve UX
This problem is supposed to be fixed in XnView MP 1.6.5. Please check and confirm the bug fix here.
fixed in 165
