Thumbnails and preview from those dng files are not shown by xnview mp
Examples of dng files can be found here:
https://www.reddit.com/r/GalaxyS24Ultra ... _of_a_raw/
https://community.adobe.com/t5/camera-r ... p/14396675
As far as I understood: Those are files with a new DNG Version 1.7
DNG thumbnails/preview are not shown
Re: DNG thumbnails/preview are not shown
DNG 1.7 uses JPEGXL, currently not supported...
pel9
thanks for clarification.
Will be JPEGXL supported in near feature?
Cheers
Cheers
JPEGXL in DNG yespel9 wrote: Mon Feb 19, 2024 8:22 pm thanks for clarification.
pel9
Hi, this is still not possible yet
Kadet
If I correctly know, XnView use libraw to decode DNG files, and now libraw use 1.6 version.
Maybe is the way to do something with that (https://www.libraw.org/node/2826), by first Pierre must look for it.
pel9
Thank you for your reply and hint. I hope that this issue can be corrected.Kadet wrote: Sat Feb 08, 2025 2:12 pm If I correctly know, XnView use libraw to decode DNG files, and now libraw use 1.6 version.
Cheers
