App UI - toolbar - reshuffle buttons
XnViewMP 1.6.4 64bit
App UI - toolbar
When switching between Browser and Viewer, the position of Rotate buttons looks very awkward.
Not only are they located in a different place, but there are substituted by similar looking Undo/Redo buttons in the Viewer.
A better approach would be to try to harmonize the position/number of buttons among groups (eg file operation, image transformation, etc.) in both modes.
default_bar.zip
(840 Bytes) Downloaded 213 times
A
  • unify groups
    - mode
    - save / export / file info
  • reposition groups
    Viewer: mode, file operations, navigation, zoom, edit/adjustment, misc
    Browser: mode, file operations, edit/metadata, misc
  • add Compare in Browser
B
similar to A, but
  • move Print to the left
  • remove
    • Undo/Redo in Viewer
      as everyone knows Ctrl+Z combination
    • Scan
      as non-important
Example
Related
Re: App UI - toolbar - reshuffle buttons
This problem is supposed to be fixed in XnView MP 1.8.3. Please check and confirm the bug fix here.
done in 183
