Background color - context menu - add predefined options
XnViewMP 1.6.4
Browser/Viewer/Preview - context menu
Sometimes it is convenient to quickly switch background color (to the predefined colors) via the context menu.
Unfortunately, this option is not available in the app.
General
  • rework background color settings
    • add predefined background colors to the context menu of
      - Viewer (Normal/Fullscreen)
      - Browser (Filelist, Preview pane)
      - Preview (Tools)
    • (options) add 2 different context menus
      1. when clicked on empty space (new menu with only Background colors)
      2. when clicked on image (current menu + Background color menu)
    • remove background color setting from
      - Settings > View
      - Settings > Browser
      - Batch convert > Settings
  • colors
    - use same colors as Capture One
    (colors are all more or less the same the across apps, see example)
A - simple menu
  • 1,2
    - same 'Background color' menu
B - simple menu
  • 1
    - same menu as in A
  • 2
    - add 'Canvas Background color' selection dialog
    - remove Viewer>Edit>Background color...
C - complex menu - preferable
  • 1,2
Example
  • context menus
  • bg colors
Related
