XnViewMP won't launch on Debian12 Xfce
BD1999
Post by BD1999 »
After struggling with installation and getting XnView installed (no gui package manager works, so the only way to install it was 'sudo dpkg -i XnViewMP-linux-x64.deb' , which worked, however, nothing happens when I try to launch it.
Is XnView not compatible with Debian 12 or is the problem with Xfce? I worked on other versions of Linux a couple of years ago - never had this happen.
I presume there are other packages that might need installing.
Before I spend another hour fighting this problem, anyone know of the secret sorcery required to fix this?
Linux Users: Because we love screwing around with an OS for an entire day to achieve 1 minute of actual work.
Re: XnViewMP won't launch on Debian12 Xfce
yes work on debian 12. when starting it in a console what do you have?
BD1999
Post by BD1999 »
Whether I launch it from console or from the GUI, nothing happens. No popups, no warnings/errors, nothing at all.
what do you have in the terminal?
