In the View mode, is there a command to disable the side miniscreen that pops up when we enlarge the image size beyond the View panel limits? The disabling would enable the capture of the image without the miniscreen. If no such disabling command exists, I suggest XNMP should create it.
[ The attached photos will show what I mean. In instance (3), there's no way around: if we capture the screen, the miniscreen will show. — The attempted attachments were not accepted: an error showed. ]
SIDE MINISCREEN IN ViEW MODE
Re: SIDE MINISCREEN IN ViEW MODE
I didn't find any setting to hide this "miniscreen"
Workaround:
do not display XnViewMP main window in full screen ;
stay in browser mode, select the chosen photo
drag and drop the "preview" outside the XnViewMP window (or into a second screen),
- enlarge this preview as much as you like ...
( and perhaps use Settings > Mouse > Zoom with mouse wheel )
Workaround:
Catalogage avec XnviewMP :
Please see this duplicate thread that has already been answered Hide small image displayed when zoom [Solved].
