Selecting another Map for GPS?
Peter2
Post by Peter2 »
Is it possible to select another map for GPS display, e.g. OpenStreetMap or Swisstopo or ...?
Re: Selecting another Map for GPS?
you can try gpsProvider=osm
Peter2
Post by Peter2 »
Thanks
I added to the file
%AppData%\Roaming\XnViewMP\xnview.ini
in section
[%General]
the line
gpsProvider=osm
and now it uses OpenStreetMap as background, but with a watermark "API Key required".
I think there are many other possibilities, because "the longer the more" governments are opening their data for free, common access.
Switzerland:
https://www.swisstopo.admin.ch/en/web-m ... ss-map-web
Austria:
https://maps.bev.gv.at/?trk=public_post ... /zoom/10.8
Baden-Württemberg:
https://www.lgl-bw.de/Produkte/Open-Data/
and so on ..
Peter2 wrote: Mon Feb 26, 2024 5:16 pm and now it uses OpenStreetMap as background, but with a watermark "API Key required".
yes a known issue
Peter2
Post by Peter2 »
Will you consider the possibility of integration of different map-sources (as mentioned above) or different WMS-Services?
This could be a great improvement!
Sir_MacCoy
Post by Sir_MacCoy »
Is it possible to use an url instead of just typing "osm"?
My guess is, that you can get an API-key for OSM on their website.
If you have this key, then, if it is posibble in XnView, and paste that url, you should see the map without the watermark Api Key Required.
I have an API-key for OpenCycleMap. I've pasted it instead of "osm" but it reverts back to Google.
Is it possible, that I can use an url instead?
Here is an example how it looks:
https:// tile.thunderforest.com/cycle/{z}/{x}/{y}@2x.png?apikey=xxxxxxx
You would make me, and I guess some other users, very happy. :D
Edit:
I just took a look on the website of Thunderforest.
You can get your own API-key there if you want, and if you choose "Atlas" as view, you get the same result as in XnView.
Here is the an example: https://www.thunderforest.com/maps/atlas/preview/
So, In XnView the url should look like this: https:// tile.thunderforest.com/atlas/{z}/{x}/{y}@2x.png?apikey=xxxxxxx
Now it just depends on the developer to implement the use of an url, and you're good to go :)
