UI is unresponsible if opened from a folder with a large number of images
Litr
Post by Litr »
I dont think it is a new bug, i have noticed it for a while. But it is annoying.
I have like 95000 of UHD photos in one folder and when i launch XnView MP from there by clicking on some file the UI and image inside it appears instantly but the whole UI hangs and something is happening in the background as i can briefly see "busy" cursor.
It is like 2-2.5 second but i cannot even close window in these moments (both with ESC key or with a "close window" button).
Funny thing is that my actions (ESC or "close window" button) are registered instantly but will be executed only after UI becomes responsible.
1) XnView MP is not opened
2) Folder with a lot of UHD files (i dont think that is related to the image size AND amount of files, but just to the amount of files but i cannot prove it)
3) Launch XnView MP by clicking on some file
4) XnView MP is fully opened very fast, but UI hangs for 2-2.5 seconds
Re: UI is unresponsible if opened from a folder with a large number of images
I think that it's the time to get full file list. Windows explorer opens it quickly?
Litr
Post by Litr »
xnview wrote: Sat Mar 09, 2024 9:42 am I think that it's the time to get full file list. Windows explorer opens it quickly?
Windows explorer can show files in the root folder (where the majority of files are located) instantly, but it struggles to show all sub-folders for a couple of seconds (that green progress bar appears over the address bar, i am using Windows 10 without indexing enabled). But the Exporer's UI does not hangs and i can even click on some files or close it right here.
you can change in xnview.ini
debug=2
and send me where in the logs you have the delay?
Litr
Post by Litr »
Again, sorry for the late reply. Here is the log (XnView MP 1.9.8, Win 10 x64, a 5 year old, but still pretty good PC with an NVMe drive)
I tried to disable the database, but with zero difference. :(
==> 1.500000  1.500000  93.298685  96.000000
XNVIEW restoreGeometry before : 640 480
XNVIEW restoreGeometry after : 1750 1379
ARG[] = C:\soft\XnViewMP_x64\xnviewmp.exe
ARG[] = G:\test\test.png
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 255, 255, 255, 178'
QCssParser::parseColorValue: Specified color without alpha value but alpha given: 'rgb 0, 0, 0, 255'
Create window finished
ThumbLoaderThread :: stop()
@@ BitmapResizeThread:: clear
MyView::change G:/test/test.png
###### GFF:load <G:/test/test.png>
### resetViewport (00000235C9C6D860)  ==> 1750 1279  (1750 984) 0 0
SORT the list...
SORT the list... 0
SORT the list... 0
setCurrentFilename <G:/test/test.png>
#### onCurrentChanged 0
LOAD INFO <G:/test/test.png>
10  IHDR 13
29  pHYs 9
3e  IDAT 1048576
10004a  IDAT 1048576
200056  IDAT 1048576
300062  IDAT 1048576
40006e  IDAT 1048576
50007a  IDAT 1048576
600086  IDAT 1048576
700092  IDAT 1048576
80009e  IDAT 1048576
9000aa  IDAT 925436
  LOAD INFO <G:/test/test.png> ok
ThumbLoaderThread - ADD into DB (-1)
QThread::setPriority: Cannot set priority, thread is not running
### ThumbLoaderThread :: setFileList(0)
### ThumbLoaderThread :: setFileList() wait
######ThumbLoaderThread :: run : cdce60e0
######ThumbLoaderThread :: forever : cdce60e0
 ** start condition wait
### ThumbLoaderThread :: setFileList() after wait
 ** start condition wake one 2
######ThumbLoaderThread :: forever 2 : cdce60e0
CHECK <0>
## OPEN FOLDER
## Check folder
  ## Check companion  68
  ## Check companion ok  68
  ## OPEN DB FOLDER ok  217
  ## UPDATE DB FOLDER ok  217
  ## OPEN FOLDER ok  235
## updateLabel  235
## updateLabels ok  235
SORT the list...
SORT the list... 1149
## OPEN FOLDER done  1509
#### onCurrentChanged 10
############### UPDATE MENU ############
Litr wrote: Tue Jan 06, 2026 4:39 pm Again, sorry for the late reply. Here is the log (XnView MP 1.9.8, Win 10 x64, a 5 year old, but still pretty good PC with an NVMe drive)
after "############### UPDATE MENU ############" ui is locked?
Litr
Post by Litr »
xnview wrote: Wed Jan 07, 2026 7:25 am
No, the unlocking happens immediately after this line appears in the log window.
Or, more precise, the unlocking occurs between these lines, as they appear almost simultaneously, so I'm not sure when exactly it happens.
SORT the list... 1154
and
after which line it locks? "SORT the list... 1154"?
Litr
Post by Litr »
xnview wrote: Wed Jan 07, 2026 3:35 pm after which line it locks? "SORT the list... 1154"?
I must note that it does not LOCKS it UNLOCKS at the end of the log. The whole UI is not responsible until it "unlocks".
Like i see the line "SORT the list...", then there is a pause in the log window (while i wait till UI unlocks), and then the rest of the log is being populated (all the lines at once) while the UI finally unlocks for the first time.
But the log is populated way too fast to determine where exactly the actual unlock happens. So all i can tell that the UI is unlocked at some point after "SORT the list... 1149", so it could be after "SORT the list... 1149" or after "############### UPDATE MENU ############"
so you have "SORT the list...", as i see there is here 1.5s to sort the filelist. 1.5s is the delay when ui is locked? Which sorting order do you use?
Litr
Post by Litr »
xnview wrote: Mon Jan 12, 2026 9:26 am so you have "SORT the list...", as i see there is here 1.5s to sort the filelist. 1.5s is the delay when ui is locked? Which sorting order do you use?
Yeah maybe, it feels like a couple of seconds but maybe it is 1.5s in reality.
Modified, Descending, Numeric order.
I open the images not through XnView Browser, but through a different file manager, if that makes any difference.
Litr wrote: Mon Jan 12, 2026 4:09 pm I open the images not through XnView Browser, but through a different file manager, if that makes any difference.
If you try to change in browser 'sort by name', same delay?
Litr
Post by Litr »
xnview wrote: Tue Jan 13, 2026 7:17 am If you try to change in browser 'sort by name', same delay?
A bit faster... i think. :| But the UI lock is still here.
I have rebooted my PC since last time, so here are the new log entries
sort by name:
SORT the list...
SORT the list... 777
SORT the list... 778
## OPEN FOLDER done  1139
sort by modified date:
SORT the list...
SORT the list... 1009
## OPEN FOLDER done  1366
could you try rename your xnview.ini/xnview.db, and start with a clean one
Litr
Post by Litr »
xnview wrote: Tue Jan 13, 2026 1:20 pm could you try rename your xnview.ini/xnview.db, and start with a clean one
Deleted ini
Deleted db
No major changes
SORT the list...
SORT the list... 784
## OPEN FOLDER done  1174
Same UI lock as before, little pause, and then it starts to analyze all these files as i can see in the logs a lot of lines, i assumed XnView was trying to add all these images to the database, so I closed it.
