RC1: Can't open files in view as list mode (only my ini)
Locked
ckv
Post by ckv »
Subject says it all. I can't open files in browser if the view as list is on. This doesn't occur with clean ini t and my ini is created byhe RC1, so this isn't ini incompatibility bug.
Get my ini: [EDIT]
Xyzzy
Post by Xyzzy »
Proper image files not recognized as image type in List mode despite Scan file headers in folders as Always.
Bug IMO.
X.
ckit
Re: RC1: Can't open files in view as list mode (only my ini)
Post by ckit »
ckv wrote:Subject says it all. I can't open files in browser if the view as list is on. This doesn't occur with clean ini t and my ini is created byhe RC1, so this isn't ini incompatibility bug.
Get my ini: xnview.ini
Confirmed.
Xyzzy wrote:Proper image files not recognized as image type in List mode despite Scan file headers in folders as Always.
Bug IMO.
Right, a bug. But if scan file headers is 'Never', do you think that this behaviour is normal? I don't know if it's a picture or not.
Xyzzy
Post by Xyzzy »
Bug IMO.
In Thumbnails and Details you know filetype anyway, because files were scanned for thumbnail creation /details display.
In List/Icon modes there is no need to scan image headers at all- what for? These modes are supposed to be speedy at first place. You use just extensions.
So actually two problems appear- 1. how to handle files that cannot be recognized by header (are there any?; Thumbnails and Details only) & and 2. files with wrong extensions (Icon/List).
My suggestions:
1. We already have option to open unknown files in XnView so nothing is needed for in Thumbnail/Details.
2. Introduce option like 'Try to define type based on header on Open in List/Icon mode for unknown file type' to handle bad extensions in List/Icon. This would attempt to define file type for unknown file when it is Opened.
3. Remove 'Recognize only by extension' & 'Scan file headers in folders'. I don't see use for them, maybe because I do not understand their purpose completely.
And to answer your question directly- if extension is OK, file should be Opened. If extension is bad, depends on setting from point 2 and action for Other files in Browser>Open action. If "option 2" is ON, file is displayed because it is recognized by header on Open. If "option 2" if OFF and Other files are Opened in XnView, I think file is displayed by XnView, because when handling Open action for Other filetype XnView tries to define its format any way it can (including headers scan).
EDIT: One more problem: what should happen when Opening, if file thumbnail/preview is not displayed because of Items displayed size limit?
I guess that file type should be recognized anyway- reading some bytes from beginning of file (and even from the end) is instant in comparison to thumbnail creation, so no big delay here.
Another solution: add options similar to "option 2" above, but referring to Thumbnail/Details view.
X.
ckv
Post by ckv »
Seems to be fixed in RC2.
Locked
