Can't create ouput file when using -o option and relative path [Solved]
Welsh
Post by Welsh »
Hi all
As I'm trying to use nconvert within a btach file under windows, I'm facing a problem using relative paths.
Here it is :
Initial directory structure
- originals
    - family
        - doe
        - smith
    - friends
- web
I just want to resize every file in the whole originals directory structure and put the results in web directory reproducing the directory structure.
So I use this commande line in a batch file :
for /f %%I in ('forfiles /s /m *.* /c "cmd /c echo @relpath"') do nconvert  -ratio -rtype lanczos -rflag decr -rflag orient -resize 1920 1200 %%~I -o "..\web\%%~I"
It looks good but when executing it i face a message
Error : Can't open file (-o)
Error : can't open file (..\web\.\family\doe\file.jpg)
I just copy one line command which is a result like :
nconvert  -ratio -rtype lanczos -rflag decr -rflag orient -resize 1920 1200 .\family\doe\file.jpg -o "..\web\.\family\doe\file.jpg"
Am I missing something ?
Thanks in advance
Welsh
Re: Can't create ouput file when using -o option and relative path [NConvert 7.121]
Post by Welsh »
Hi all
I was missing something...
My command line is :
But nconvert command line should be
nconvert options file
So my command line is treated as if `-o "..\web\%%i"` should be 2 files to be processed..
So putting the command line members in right order and everything is ok.
nconvert  -ratio -rtype lanczos -rflag decr -rflag orient -resize 1920 1200 -o "..\web\%%~I" %%~I
Sorry this mistake.
Welsh wrote: Sun Mar 03, 2024 10:36 am I was missing something...
Thanks for reporting back!
I have always used the order shown, but didn't question your order as I have recently been wondering if it was actually needed, and as far as I know it is not formally documented.
