Compare image move & zoom should be independetly
mokati
Post by mokati »
problem:
i want to compare 2 pictures with different picture sizes.
if i move one picture the second one is following the movement, but the size is different.
proposal:
to move and zoom each picture individual.
thus i can compare 2 pictures better (e.g. different picture qualities, resolutions)
m.Th.
Re: Compare image move & zoom should be independetly
Post by m.Th. »
Try to keep CTRL or SHIFT or ALT pressed when you move/zoom with the mouse a certain image.
m. Th.
mokati
Post by mokati »
great thanks, it works well !
you can close my ticket
