I have a small image to be printed: 8.5 x 5.3cm only, but on screen it is much larger.
Probably because of the high DPI.
Vainly searched how to print this using the actual size.
Any suggestions?
Thanks!
How to print with the actual sizes (W X H)
mrwul
Re: How to print with the actual sizes (W X H)
The answer seems to be to use the Print... > Page layout -- Single - DPI option...mrwul wrote: Mon Mar 04, 2024 8:53 am I have a small image to be printed: 8.5 x 5.3cm only, but on screen it is much larger.
But that possibly raises an issue with the Print dialog design, doesn't it? Possibly better one of the following:
Single - DPI size
Single - Size from DPI
Single - Actual size
mrwul
Super.
Thank you!
That worked out fine.
Thank you!
Possibly clearer dialog text for that option one of the following:
Single - DPI size
Single - DPI size
mrwul
Agree. I wish at least "Actual Size" would be added.cday wrote: Mon Mar 04, 2024 10:08 am Possibly clearer dialog text for that option one of the following:
Single - DPI size
For now I know I should use Single DPI, but I guess "Actual Size" would have been clearer right from the start.
Anyway, thanks again.
