Hi guys
With my camera Sony NEX-7 it is possible to take pictures both in RAW-format AND JPG-format together. Opening MS Explorer both files are visible (see Clipboard 1.jpg), whereas in browser mode of XnViewMP only the RAW-file is visible (see Clipboard 2.jpg). Why is the JPG-file not shown?
Photos in RAW-format and XnViewMP
Bronimus
Kind regards / Schönen Gruß vom Bronimus
Windows 11 Home, XnViewMP 1.8.6 64-bit
Re: Photos in RAW-format and XnViewMP
check 'Show companion files' in
Settings > File list > Companion files
Bronimus
perfect answer - now the jpg-file ist shown
thx a lot
thx a lot
