1.6.5 - view - transparent index visible when zooming
XnViewMP 1.6.5 64bit
Viewer/Browser(Preview) - indexed palette
1. open test image in Viewer
- ☑ Use transparent index (<=8bits) [default state]
index 1 (green) is transparent
Issue A
2. press M to "Show alpha"
nothing happens at default 100% zoom
3. zoom to any value <>100%, eg 71%
transparent index became visible
expected behavior
for indexed color images without alpha, "Show alpha" command should:
  • either be disabled
    like in Preview pane (Browser) and other Show RGB channel commands
  • or work at any zoom level
    as functionality to show transparent index(es) is handy, only naming does not match, but not a big deal
Issue B
2. uncheck 'Use transparent index (<=8bits)', eg via Ctrl+Alt+H
index 1 (green) is visible
index 1 (green) became transparent
same issue in Preview pane (Browser)
  • rename
    Use transparent index (<=8bits) →
    Use transparent index (≤ 8-bit)
    ≤ U+2264
    8-bit color
    8 bits per pixel
Related
Re: 1.6.5 - view - transparent index visible when zooming
Issue A: I can't reproduce
Issue B:
xnview wrote: Mon Sep 30, 2024 12:43 pm Issue A: I can't reproduce
1. close app
2. open paletted image (8bit, no alpha) via double click in win file explorer
'Show alpha (M)' menu command is enabled
3. change zoom to any value <>100%
4. press M
issue appears
Show alpha (M) is disabled - as it should be for paletted image
Strange, 'show alpha' is disabled
fixed in 181
