JXL export always strips Color Profile
rotbus19
Post by rotbus19 »
Export... JXL always strips embedded Color Profile causing a color shift in the image. cjxl has an option to keep the color profile:
 -C K, --modular_colorspace=K
    Color transform: -1 = default (try several per group, depending
    on effort), 0 = RGB (none), 1-41 = fixed RCT (6 = YCoCg).
Could this option be exposed so we can export to JXL and keep Color Profile?
Note - if anyone wants an easy way to convert to JXL and keep Color Profile - https://github.com/JacobDev1/xl-converter
Re: JXL export always strips Color Profile
with 1.6.5?
rotbus19
Post by rotbus19 »
yeah
if source image has color profile, JXL will have it.
test.zip
could not delete Color profile from loaded image
to reproduce
1. open test image in Viewer
test_img_color_profile.zip
issue A
2. Clean metadata (Metadata menu)
- check ICC profile
- press OK
3. press Ctrl+S to resave JXL
image still has color profile
issue B
2. goto Settings > Write
- uncheck Keep ICC profile
expected behaviour
guess these 2 approaches should be legit ways to remove metadata from images
libJXL add a profile when saving
