RC1: Label with comments not displayed
Locked
Dirk
Post by Dirk »
Sometimes comment labels are empty in the browser view - but they exists!
Dirk
Re: RC1: Label with comments not displayed
Dirk wrote:Sometimes comment labels are empty in the browser view - but they exists!
Please send me a sample?
Dirk
Post by Dirk »
Hi Pierre
sorry - I'm at work and made only a short test. This test was not very meaningful.
E.g. if I use "set comment" or "Copy IPTC caption to comment" then labels with comments are displayed. Then e.g. close XNView and start XNView - all comments are not shown. Rarely comments displayed.
I could send you a sample!
bye Dirk
Dirk wrote:Hi Pierre
Do you have enabled the cache?
Dirk
Cache problem?
Post by Dirk »
Hi pierre,
yes - it was enabled. Now I disabled the cache and at the moment I can't produce this bug. Therefore it seems to be a cache problem!?
Dirk
Dirk
Fixed
Post by Dirk »
I could NOT reproduce it - seems to be fixed. :bugfixed:
Locked
