Problem:
When filling out metadata for many images, it is tedious to jump through the 5 tabs to add just one entry at a time.
Proposal:
It would be great if you had your own tab (user-defined) with a collection of comment fields where you could fill your own fields without having to constantly jump between tabs.
see example image.
For the gallery, the metadata for the images can also be displayed individually in the options.
option-Window to select the user-defined entries could be possible at the options
IPTC/XMP Metadata with user-defined Tab
mokati
cicciobello
Re: IPTC Metadata with user-defined Tab
Really a great idea, but I think it's difficult to implement.
