Large Image Processing Bug: Part 3
pinchies
Post by pinchies »
Hi again,
I'm having issues processing large images with the Unsharp mask function. The program (XnView/XnConvert) crashes once the filter is enabled, and seems to be repeatable.
Sample Image: https://www.dropbox.com/scl/fi/m150fi6r ... a2qie&dl=0
I was using Radius 4px, Amount 3.00, Threshold 3.00.
Using XnConvert Version 1.100.1 - windows x64 (Feb 25 2024)
Thank you kindly.
Re: Large Image Processing Bug: Part 3
which image size?
pinchies
Post by pinchies »
The image I used (see link in first post) was 25918 × 36478 pixels.
