Image orientation wrong
alee001
I often find that some pictures have the wrong orientation. When I use File Explorer to display the original orientation of the picture, it is portrait, but when I use the XnView browser to display the picture, it changes to landscape. If I enter edit mode, it returns to portrait (as shown in the picture)?
Re: Image orientation wrong
please send me the sample file
alee001
3 sample JPG (If any changes are made to this image, the correct orientation will be restored in Xnview.)
the embedded thumbnail is landscape not portrait.
alee001
Yes, the picture is a portrait but the thumbnail error in Xnview is landscape.
i means the embedded picture in the file
alee001
A JPG file with an embedded image, do you mean it is an image similar to a compressed file?
in JPEG file, you have the image and a thumbnail. Check by disabling 'Settings>Thumbnails>Use embedded...' and 'View>Rebuild thumbnails'
alee001
I understand, now the problematic pictures can be restored to the correct direction, but I need to select all the problematic pictures to do it, and other problematic pictures will not be automatically corrected. I hope this can be improved, thank you.xnview wrote: Thu Apr 04, 2024 7:00 am in JPEG file, you have the image and a thumbnail. Check by disabling 'Settings>Thumbnails>Use embedded...' and 'View>Rebuild thumbnails'
