v1.7.0 - no more click to zoom?
phaolo
Post by phaolo »
When updating to v1.7.0 I lost a feature that I found useful, expecially when comparing similar images.
In the old version i could click any part of a picture to temporarly zoom-in to real size and zoom-out (back to fit view) on release.
It was way faster than using any zoom control.
What happened, could you please restore it?
Re: v1.7.0 - no more click to zoom?
use SHIFT+LMB or
change it in Settings>Interface>Mouse
phaolo
Post by phaolo »
user0 wrote: Mon Apr 01, 2024 3:28 am use SHIFT+LMB or
Ah cool, there's "Zoom & move" among those settings.
Perfect, thanks :D
BK201
Post by BK201 »
Glad it's still there
Would be better if just keep the old behavior and add new ones instead of forcing user search the forum to find out "where is X feature" every few versions
BK201 wrote: Wed Apr 03, 2024 11:13 am Glad it's still there
yes an error from me
phaolo
Post by phaolo »
xnview wrote: Wed Apr 03, 2024 12:15 pm yes an error from me
There seems to be a different behaviour with "Zoom & move" tho.
In older versions, if the image was already zoomed in, left click just moved it around.
Now instead it zooms out (?)
Could you please leave the zoom-in, but stop the zoom-out?
Otherwise the "move" option becomes limited to only large images.
