Moderators: xnview , Dreamer
Hakim Antoine Said
Posts: 193 Joined: Sat Feb 04, 2023 8:39 pm
Post
by Hakim Antoine Said » Tue Apr 02, 2024 12:06 am
in Draw Board, When I Use the Text Option ,
It's Literally Impossible to Write Entire Paragraphs , It's Impossible, XnView MP Goes Crazy, It Gets Extremely Slow, And Then... The Software Stops (it Gets Crash)
this bug has been around for a long time, but now it is impossible for me to write paragraphs,
the software always stops , I have to resort to using another software for that text function
It is a very annoying bug, so annoying that it is impossible for me to write paragraphs
Note: Even if i disable text effects, the slowdown still occurs, it Gets Extremely Slow and Gets Crash anyway
Please Pierre fix this bug, thank you very much
Always Keep Going
Posts: 48213 Joined: Mon Oct 13, 2003 7:31 am
Post
by xnview » Tue Apr 09, 2024 7:29 am
how many lines?
Post
by Hakim Antoine Said » Tue Apr 09, 2024 8:44 am
xnview wrote: Tue Apr 09, 2024 7:29 am how many lines?
from 2 lines onwards the slowdown occurs, i can write but very VERY slowly appears the letters when i write
from 3 lines onwards it is impossible to write and the software gets crash
Always Keep Going
Post
by xnview » Tue Apr 09, 2024 1:47 pm
i can't reproduce, sens screenshots of settings used & text
Posts: 3060 Joined: Sat May 09, 2015 9:37 am
Post
by user0 » Tue Apr 09, 2024 2:13 pm
can reproduce slowness with text FX disabled
but on my pc it requires 60Kb of text pasted >5 times to start lagging
draw_text_lag_test.zip
Post
by Hakim Antoine Said » Wed Apr 10, 2024 5:56 am
xnview wrote: Tue Apr 09, 2024 1:47 pm
After researching....
I know what the problem is here
It is the
effect called "
OutLine ",
that is what makes the slowdown occur
by disabling that effect, you can write fluently
case closed
Pierre ....
Can you improve the OutLine effect to be able to use it and write fluently
Always Keep Going
Post
by user0 » Wed Apr 10, 2024 6:28 am
Hakim Antoine Said wrote: Wed Apr 10, 2024 5:56 am
It is the
effect called "
OutLine ",
so, you finally remembered your own comment on the same topic..
[feat] draw - text - slow Outline effect
Post
by xnview » Wed Apr 10, 2024 6:34 am
Pierre ....
Currently it can be slower when using outline, i'll check if there is a better way with Qt
Post
by Hakim Antoine Said » Thu Apr 11, 2024 2:17 am
user0 wrote: Wed Apr 10, 2024 6:28 am
HaHaHa Hello My Friend
i Thought That Bug Was Fixed, But it is Not Yet
i know Very Soon Shall Be Fixed
Last edited by Hakim Antoine Said on Thu Apr 11, 2024 2:23 am, edited 1 time in total.
Always Keep Going
Post
by Hakim Antoine Said » Thu Apr 11, 2024 2:19 am
xnview wrote: Wed Apr 10, 2024 6:34 am
Thank You Pierre , i Know You´Re Gonna Fix That Bug
Always Keep Going
Post
by Hakim Antoine Said » Thu Apr 11, 2024 2:31 am
user0 wrote: Tue Apr 09, 2024 2:13 pm
can reproduce, but on my pc it requires 60Kb of text pasted >5 times to start lagging
Hello My Friend user0....please tell me what are the specifications of your pc
graphics card
RAM
HDD or SDD
Thanks My Friend
Always Keep Going
