Now I have this problem the second time: I used color-labels (red) for around 850 Photos (.jpg) out of 35-40 folders to fill them into a photobook.
I saw the photos, switched to the details-view to give them another order - by path instead of filename. Switched back to view Thumbnails with filename, all ist fine.
Then, I choose another label (yellow) to check other selections. Back to color-labels RED - ALL labels gone! Zero Files with label red!
Did anyone else encouter this problem and, perhaps, has a solution?
Many thanks and regards
Peter/Germany
Color labels suddenly not there anymore
Re: Color labels suddenly not there anymore
with latest version? Are you able to reproduce?
PeterSKO
Yes, latest version 1.7.0 64 bit MacOSX Libformat 7.174
Unfortunately I think I can't reproduce. But the same happened some months ago.
I now try with an other color of label (yellow instead of red)
Regards
Peter
Regards
Peter
do you use catalog only?
PeterSKO
I think so...? I use the standards after installing.
But I encountered two more things:
1. There is one menu-topic, that is in english instead of german - see attachment
2. I chose my photos as described in opening thread, labeled them and showed them in Catalog Filter/Color Label and ordered them by "path"
when I open them from the Browser in Fullscreen, all is fine, the sequence is as shown in the collection
But when I open them by Doubleclick first, the sequence is incorrect, orders seem by Filename! Then I display with Fullscreen,
there also is the wrong sequence! The sequence is only right, when I open the file in the browser (no matter of View in DETAILS or THUMBNAILS)
and choose FULLSCREEN from there!
Regards
Peter
Regards
Peter
If you find a way to reproduce this problem??
ok1. There is one menu-topic, that is in english instead of german - see attachment
Please create another post2. I chose my photos as described in opening thread, labeled them and showed them in Catalog Filter/Color Label and ordered them by "path"
