Version 1.7.0
- open an uncompressed TIFF
- Properties with Alt+Return: "no compression" (correct)
- "Save as tiff with compression"
- Properties with Alt+Return: "no compression" (NOT correct)
- close and open the tiff
- Properties with Alt+Return: "compressed with ...." (correct)
Or:
- open a TIFF
- Properties with Alt+Return: "Image Format: TIFF" (correct)
- "Save as JPEG"
- Properties with Alt+Return: "Image Format: TIFF" (NOT correct)
- close and open the JPEG
- Properties with Alt+Return: "Image Format: JPG" (correct)
Properties (Alt+Return): not refreshed correctly
Peter2
Re: Properties (Alt+Return): not refreshed correctly
please send me sample files
Peter2
I don't think that it is depending on the file. I attach a screenshot, made by XnView - and it does the same.
i can't reproduce, Properties show properties for current file.
