Keyboard shortcut "/"
Magistair
Post by Magistair »
Subject: 1.7.0 : Default keyboard shortcut "/" inop.
XnView: MP 1.7.0 - 64-bit
Windows - 64-bit
Effect: resuming fullscreen display of image after zooming in/out using "/" inoperative.
1. Select image file;
2. Open fullscreen (view) using F11 key;
3. Press "*" to see the image (actual size);
4. Press "/" to restore fullscreen view.
Actual behaviour (bug): nothing happens, image stays actual size.
Like if "/" was inop (though being checked as default shortcut in parameters).
Expected behaviour: fullscreen display restored.
Re: Keyboard shortcut "/"
Magistair
Post by Magistair »
Checked it, doesn't work.
Also tried to assign (the same or other) through "Personal", doesn't work either.
default action assigned to / has changed in 1.7.0
you can reassign it in Settings > Interface > Shortcuts
but there is a bug that requires app restart after reassigning shortcut
Magistair
Post by Magistair »
Unable to reproduce what happens in the link.
Enclosed see :
"Settings.jpg" - the default status
"PopUp.jpg" - what happens when I try to assign "/" to fitAll (fitWindow doesn't appear).
So unable to go farther.
1. unassign "/" from "Fit image to window, large only"
2. assign "/" "Fit image to window"
3. press OK, restart app
Magistair
Post by Magistair »
Did it as prescribed:
1. unassigned "/" from "Fit image to window, large only" by selecting "Aucun"
2. Assigned "/" to "Fit image to window", was assigned as "Personalised"
3. Clicking OK, a PopUp "Save as... -.keys", did it
4. Restarted app, had to load personalised "keys" file
5. Doesn't work...
Note: restarted app, the (personalised) key was active by default this time, but still doesn't work.
Sorry :?
in Shortcuts, there is combobox in the top left corner, change it from Browser to Viewer
also no need to Save..., just press OK
Magistair
Post by Magistair »
Problem solved!
Thanks a lot!
(And I'll buy spectacles... :wink:)
