please add {bits per pixel} for title bar or Info
support status bar maybe better
easy to estimate compress ratio
dapingxiong
dapingxiong
Re: please add {bits per pixel} for title bar or Info
thanks for your reply
l've tried {Bpp} on MP1.7 and 1.63
it shows bits of image like 24 or 48
maybe something wrong with my setting
If different versions show different bpp for the same image, that's a bugdapingxiong wrote: Mon Apr 08, 2024 3:36 am l've tried {Bpp} on MP1.7 and 1.63
If this is not the case, what do you expect to get?
24 bit per pixel (24 bpp) means there are three 8-bit channels (8 bpc) (wiki: color depth)
there is no {bpc} tag in the app
Compression ratio (besides the obvious "more bits - potentially better quality") is format dependent.
dapingxiong
image file Size(MB)*8 / MPixels
