1.7.1 - viewer - save - sometimes image XY DPI is not saved
XnViewMP 1.7.1 64bit
Viewer - save
0. clean unziped app version
☑ Use EXIF DPI (if exists)
☑ Adjust image if X/Y DPI re different
1. open any image in Viewer, eg test one
test_img_XY_DPI.zip
2. open Image > Set DPI...
☑ Change EXIF DPI if exists
- change XY, eg to 2x72
- press OK
image shrinks/stretches according to the entered values
3. press CTRL+S to save image
4. reopen app and image
image has no XY DPI
however, 10x72 saves without issues
Re: 1.7.1 - viewer - save - sometimes image XY DPI is not saved
the JPEG library seems to check that dpi value has a minimum value
same issue with other formats, eg bmp, gif, png
right, at loading, if dpi is <= 2, it's not a good value for me
hm, why not.. if there is weird XY DPI - just render them as is, it's user problem to fix their image
especially if related setting is checked in Settings
also, not sure why there is no DPI field (in Properties>Image) for the file with <=2 dpi (test_img_XY_DPI_result_2x72).
If it exists inside file - it should be displayed, if does not exist - why it has not been saved?
