Viewer order is broken when using Fillter+Path order
hjaki
Post by hjaki »
Similar to this bug
viewtopic.php?f=96&t=46975
1. Catalog Filter to filter across multiple folders(e.g. Rating Excellent)
2. Set sort to Path
3. Double click to open the viewer
4. Viewer shows files in order by name
For example, there are folders and files like this:
Root/
├── Folder01/
├── Folder02/
├── Folder03/
This is the order in which the thumbnails are displayed:
Folder01/01.jpg
Folder01/02.jpg
Folder02/01.jpg
Folder02/02.jpg
Folder03/01.jpg
Folder03/02.jpg
The actual display order is this:
Folder01/01.jpg
Folder02/01.jpg
Folder03/01.jpg
Folder01/02.jpg
Folder02/02.jpg
Folder03/02.jpg
XnView MP Win 64bit 1.7.0 & 1.7.1
Re: Viewer order is broken when using Fillter+Path order
This problem is supposed to be fixed in XnView MP 1.7.2. Please check and confirm the bug fix here.
