Settings - general - move items
XnViewMP 1.7.1
Settings - general
its better to reshuffle settings with the following logic:
  • General tab - about app generalized behavior
A
  • move 'Show all graphic formats' into Formats tab
  • rename
    'Choose the formats which you use for saving.' →
    'Save format' (or something similar)
    as it should be list's label, not a hint
B
  • move 3 items into View tab
    - Auto-rotate images according to EXIF orientation tag
    - Use EXIF DPI (if exists)
    - Adjust image if X/Y DPI are different
Related
