Settings - view - pixel aspect ratio - improve data readability
XnViewMP 1.7.1 64bit
A
  • rename
    - Pixel ratio → Pixel aspect ratio (PAR)
    - WideScreen → Widescreen
  • move decimal ratio to the left
  • sort by decimal ratio
B
same as A, plus
  • update ratio decimal values to match Adobe apps / Davinci Resolve
Example
  • Davinci Resolve
Related
Re: Settings - view - pixel aspect ratio - improve data readability
This problem is supposed to be fixed in XnView MP 1.7.2. Please check and confirm the bug fix here.
done, but some alignment required
UPD
also it looks like only these 3 are translatable:
1.00  Square
1.90  D4/D16 Anamorphic
2.00  Anamorphic
right
