Ctrl+D to Edit Comment not to Rename File
zohozer
Post by zohozer »
I am using frequently The Ctrl+D shortcut to quickly add notes to my pictures and I do like to add the comment as fast as possible. Unfortunately into the latest versions of XNview, it is a big regresion about this feature, because now when I do press the Ctrl+D shortcut instead of the prompt to be into the first box of the Embed Comment textbox, it is pointing by default to the Name of the File box, so now if I quickly press Ctrl+V to paste the comment and quickly press Enter will result in changing the name of the picture instead to add the comment to the file.
Please change back the default filed of the cursor to be on the Embed Comment box insttead of the Rename File box when pressing the Ctrl+D shortcut keys.
https://SecreLocal.com - Talk To Girls - No Verify - Anonymous Sex Dating - Local Live Dating Chat
Re: Ctrl+D to Edit Comment not to Rename File
This problem is supposed to be fixed in XnView MP 1.7.2. Please check and confirm the bug fix here.
