Screen Shot in XnViewMP?
GeorgeH
Post by GeorgeH »
Where do I obtain Screen Shot function when I open XnView.
Re: Screen Shot
GeorgeH wrote: Fri May 03, 2024 5:45 pm Where do I obtain Screen Shot function when I open XnView.
For me, in Linux Mint but also I think in Windows if I booted into it, using the Print Screen key on the keyboard '(Prt Sc' on my keyboard).
GeorgeH
Re: Screen Shot
Post by GeorgeH »
Not sure what a Linux is. Do I need to load that software onto my computer. No icon on provided on XnView?
Re: Screen Shot in XnViewMP?
Do you see a Print Screen key somewhere on your keyboard?
I don't think that there is an option to add an icon on the toolbar.
GeorgeH
Post by GeorgeH »
i believe it is on F10 button. So I guess I hi-light the text and push "prt sc" button for screen save? Nothing happened when I used the prt sc button
GeorgeH wrote: Fri May 03, 2024 6:03 pm i believe it is on F10 button. So I guess I hi-light the text and push "prt sc" button for screen save?
The Print Screen key captures the whole screen, so you first need to open the saved screen image, and then if you only want part of the screen you need to crop the image created and save it.
Another way would be to make a selection around the text you want on the original image, then paste the selection onto a new blank image canvas created using File > New image... .
And if you need to paste the text into a word processor, for example, you would need to convert the text image into searchable text. There are freeware tools for that, and if the original image on the screen is good quality you could use an [OCR] software directly on that image, without needing to make a screenshot. One such OCR software which seems to work well is NAPS2.
Kadet
Post by Kadet »
First You click "Capture" icon.
Then You choice what to do.
Click "OK" and then F10 when You need to made Screenshot(s).
@Kadet: Thanks for that, I was aware of the file browser menu item Tools > Capture... , but hadn't realised that there is now a viewer toolbar icon.
Pressing the Print Screen keyboard key and then opening the saved image doesn't take long, but using the viewer icon will also be easier for me... :D
The other Capture options could also sometimes be useful.
