I am a big fan of the presets in XnviewMP batch conversion mode.
I use different presets for special conversion jobs.
One of my presets use the JPEGLI encoder and quality 80%.
The presets for batch conversion save the jpegli encoder, but does not save the jpeg quality level (e.g. 80%).
In the past the jpeg quality level was saved in the preset. Maybe the reason is, that the jpegli encoder is optional?
It would be nice, if you could fix it.
XN-MP 1.71 - Batch conversion - presets does not save jpeg quality
masterjp
Re: XN-MP 1.71 - Batch conversion - presets does not save jpeg quality
This problem is supposed to be fixed in XnView MP 1.7.2. Please check and confirm the bug fix here.
