Previous/Next tab shortcut
bipbip
Post by bipbip »
Could you add the option to set the shortcut to open the previous or next tab. I figured out you can change tab with CTRL + TAB and CTRL + SHIFT + TAB like in a browser so it's implemented but it cannot be changed. It should be nice to be able to change tab with the mouse wheel too (to do CTRL + mouse wheel for example).
Also I noticed that the shortcuts CTRL + TAB and CTRL + SHIFT + TAB don't work in fullscreen unfortunately.
