Extract ICL-Archive
Tamaleus
Extract ICL-Archive
Post by Tamaleus »
I hope did not oversee existing entry regarding my question.
I have File named "windowsxp.icl". As far as I understood, this is supposed to be Archive containing Windows (XP) Icons, which I'm looking for. However, so far I did not manage to extract this File, showing all contained *.ico (?) Files.
I downloaded NConvert and tryed command (at Dos-Promt/cmd):
nconvert.exe -xall windowsxp.icl
Unfortunately it did not work. Answer was:
** NCONVERT v7.172 (c) 1991-2024 Pierre-E Gougelet (Feb 19 2024/14:50:40) **
Version for Windows 7/8/10/11 x64 (All rights reserved)
** This is freeware software (for non-commercial use)
Error: Don't know how to read this picture (windowsxp.icl)
What's my mistake? How to get Content of *.icl-File? (Size ca. 1'692 MB)
Tks+Greetings
Tamaleus
Tamaleus
Re: Extract ICL-Archive
Post by Tamaleus »
Solution found on https://www.towofu.net/soft/e-aicon.php
In case, download at towofu.net still does not work, check at Heise (https://www.heise.de/download/product/i ... 4/download) or similar.
