Favorite folders with outdated directories
forklab
Post by forklab »
Favorites to non-existent folders bugs.
1.7.1 64-bit
I've added some dir to favorites some time ago then directory was moved to other location.
1. Open XnView MP
2. Favorites selected, there are this one favorite location
3. Click at it
4. "This favorite ... not exist. Do you reallt want to delete?" - message is out of context, I don't want to delete. Press "No"
5. RMB > Change path > Select correct path, Apply this directory
6. Click at it again - main panel changed path and shows dirs/files, seem ok...
7. Close XnView MP
8. Repeat 1-3. 4 occurs again as I did not changed path at previous run.
9. RMB at this favorite, Delete
10. Close XnView MP, Open XnView MP
11. "Deleted" favorite raised from the death.
Re: Favorite folders with outdated directories
This problem is supposed to be fixed in XnView MP 1.7.2. Please check and confirm the bug fix here.
forklab
Post by forklab »
Now it seems ok.
