HIF thumbnails not rotated properly
I am using 1.7.1 on Mac Ventura 13.6.7.
My Sony A6700 HIF files which are shot as verticals (portrait orientation) are not displayed properly in the grid thumbnail view. When I open one to display it though it is displayed in the proper vertical orientation. Please display the thumbnail properly too. Thank you.
Re: HIF thumbnails not rotated properly
I sent you a Sony A6700 vertical HIF file to contact@xnview.com.
I also use XnView MP on a Windows 11 PC. I do not have it with me right now, but I think the Windows version has the same problem.
This problem is supposed to be fixed in XnView MP 1.7.2. Please check and confirm the bug fix here.
Thank you.
I installed 1.7.2 and I confirm that the orientation for the thumbnail and the open photo are now correct. But there is a major regression that I reported here:
viewtopic.php?f=93&t=47327
I must go back to 1.7.1.
I just installed 1.8.0, but unfortunately this bug has returned.
The HIF thumbnail is not oriented properly. When I click on the thumbnail the full size photo is properly oriented.
could you send me a again the file?pulancho wrote: Wed Sep 25, 2024 10:26 pm I just installed 1.8.0, but unfortunately this bug has returned.The HIF thumbnail is not oriented properly. When I click on the thumbnail the full size photo is properly oriented.
I resent the Sony HIF file to you about 3 minutes ago.
Thank you. The problem is fixed in 1.8.1.
