Plugins - few improvements
XnViewMP 1.7.1 64bit
Plugins
UI/functionality can be improved
A
  • UI
    - make list more compact
    - make progress bar nicer, it should be the same width as button with % in the middle
  • add Version columns
  • add Refresh button
    to manually refresh: installed/available versions
  • add Reinstall functionality
    via clicking on Install button for already installed plugin
    it is currently not possible to reinstall plugin, eg if user corrupts files in the plugins folder
  • (optional) add Languages tab (ship with English only)
    so distr will be a bit lighter and translations won't delay releases (use date as translation version)
B - preferable
same as A, plus
  • rework Install buttons into checkboxes and single Install
  • add Uninstall button
Example
cicciobello
Re: Plugins - few improvements
Post by cicciobello »
Mockup B!
